How to break into an LR3
T
toddjb123
Guest
...I think I started a post a long time ago on this or another forum regarding my disappointment with the bulky key/remote and lack of an emergency thin key for getting into the vehicle. I usually lock my keys in my car once or twice a year, no big deal, I have always had an accessable hide a key to get back in. This hasn't been an option with the rover unless anyone has a suggestion for me...PLEASE!
Here's the long story - I was down in Avon, NC last week kitesurfing (similar to windsurfing FYI). So, you park on a sand beach and head out in the water. Salt water wouldn't be good for the key fob and either way its too thick for a swimsuit pocket. So, that leaves stashing the key on the vehicle somewhere so you can get back in when you return to the beach.
What I usually do is lock the car, hide the key, and then get a couple last minute items out of the back before shutting the tailgate/window. Once you do this, the lights flash and the car is locked. I've done this before, no problem. So, I go out for a nice ride in the water, come back in to get something, open up the vehicle, close it again, and hit the water. Come back an hour later and some friends have walked up the beach to meet me. They don't have 4WD, would like a place to sit, so they look for my key to open up the tailgate and rest. Well, my key isn't there. Sure enough, I have locked it inside the car in my rush to get back out on the water. I had "locked" the car, placed the key on the rear window dash instead of its hiding place, and forgot to remove it before shutting the tailgate. So, I can see the key, but its inside the car. I'm on the beach. F*ck.
At this point I was really wishing I had GM's OnStar system so I could call up and have someone unlock my car remotely.
I'm far from a LR dealership and figured that AAA wouldn't know much more than me about getting in the vehicle, so we gave it a go. The only ****** of luck was that I had left my sunroof cracked, but had left the sunshade drawn. Luckily the sun shade is not glued on the sides so that does give some access to get into the vehicle. The first attempt (45 minutes or so) was to push that big unlock button on the center of the dash. We were able to find a long plastic cable shroud that was stiff yet flexible enough to get in the narrow opening and bend down to the button. It took several tries and a lot of finese, but finally, we were able to depress that button repeatedly. Unfortunately, as some of you may have guessed, this button is deactivated once the car is locked with the remote. F*ck.
So, the only other option was the manual unlock button on the front doors. Again, took several tries, variations, and an assortmant of items borrowed from other kitesurfers...we ended up with a bent butter knife electrical taped to the end of a fishing rod. Got the fishing rod in through the sun roof and were able to unlock the door.
Now, if anyone thinks I am giving away crucial break in advice, don't worry about it, when you open the door the alarm goes off and the car won't start. You still need to get to the remote to turn the alarm off. So as you can guess, there was a lot of cheering once we got in the car after 90 minutes of trying and we didn't care too much about the alarm while I dug for the remote and turned it off. But man that was a pain in the ass!
In summary, I really wish we could make a valet key for these things for easy hiding under the vehicle. I know there are ways to make a waterproof box for a spare remote, but I'm not one for taping a $250+ key to the bottom of my rover just in case. Any other ideas for hiding a key? Can the key be copied? (not the remote, just the key.)
The lesson here is to always keep your sunroof cracked and make sure you have access to a fishing pole, butter knife, and some electrical tape. Maybe I should tape all those things to my frame in lieu of a hide-a-key?
-todd
T
toddjb123
Guest
Yeah, they told me it was, but honestly, salt water isn't good for anything to stay submerged in. Additionaly, if you even have a pocket when you're out there for water sports something as heavy as a key fob can easily get torn out of a pocket unlike a light spare key you could just tie off somewhere. $.02
T
timbo
Guest
How about a lockbox
Lock this around a door handle or I'd bet there has to a be a more hidden spot on the undercarriage like on the spare tire somewhere.
http://www.buyasafe.com/Scripts/prodView.asp?idproduct=296
H
hysterwv
Guest
Todd,
I was in Hatteras last week as well. I did mistakenly take the fob into the ocean (was in the back pocket of my board shorts). I'm sure it's sealed well, but there was sand in every nook and cranny of the fob. The little "lock" button on the fob doesn't want to engage and the key itself was full of sand. I'm worried that I'll force some sand into the ignition switch. In the past, I've used magnetic holders to hide a key in a wheel well or trailer hitch.
FYI, the closest dealer is in Virginia Beach (quite a drive).
I saw TONS of people kite-surfing. The wind was killer. Hope you had a good trip otherwise.
F
Freeflytim
Guest
Good one Todd! Go to the LRNA website and start complaining. The remote only entry stinks. There are times that I can't stand carrying that HUGE fob either.
If you did any damage to your truck getting in make LR fix it... tell them you could not afford the DAY that it would take for them to tow it to the nearest dealer and wait for them to open on Monday... Thats all LR assist is... They don't send someone from the dealer (like Mercedes) they send AAA to tow to the nearest dealer and if the dealer is closed, you're screwed.
T
toddjb123
Guest
Hmmmm...if I thought I would get anything out of it, I'd definitely push it just to repair the minor scratches in the center dash. But I'm guessing they'd just say it was my fault. (bad design IMO, but it was my fault).
Unless "LR Assist" covers things like this? Does it? That'd be good to know in case it happens again when I'm not on a beach...
T
toddjb123
Guest
hysterwv said:
Todd,
GREAT week! Glad to hear you were there as well. Windy every day and sunny just about every day.
Yeah, that would have been my guess too. {sand} Even with normal use my key/lock button gets stuck sometimes.
If you saw a Tonga LR3 screaming down the road with all the windows down that was me! :) I also enjoy driving it with the rear hatch up while at the beach. Makes for much nicer airflow through the vehicle (but I close it for beach driving so the window hinges don't get jarred by rough terrain). Only other LR3 I saw down there was a black one in Waves one day. Did you get the LR3 out on the beach?
That MASTER LOCK shackle someone posted is a nice idea. Think it would hold a key fob?
A few pics from the trip;
my friend enjoying a beer on the tailgate after we "unlocked" it;
http://images14.fotki.com/v223/photos/6/666681/2642985/bDSC_297-vi.jpg
me out for a sail;
http://images12.fotki.com/v217/photos/6/666681/2642985/aDSC_015-vi.jpg
the locals out for a sunset sail;
http://images14.fotki.com/v219/photos/6/666681/2642985/cDSC_0187-vi.jpg
T
timbo
Guest
Well, I picked the biggest they had on the site.
"Large Key Storage compartment holds over 5 house, car or padlock keys"
It looks to be sized to hold the long industrial sized keys so it's got a shot.
