Another Defender hint?
colorover
Promising! Hood and roof need to be parallel to the ground...
bbyer
Alberta
I would like to share the optimism, but tyre size and mirrors are not much to go on.
Somehow I think rounded egg and Ford are all related; I hope I am wrong.
My new Defender solution was something that already existed - the D4 Commercial - coil springs and spartan interior, but that would have been too easy and successful.
to8nbeyond
Georgia
I think they've intentionally made it look like the LR4 the same as the prototype they were driving around several months ago looked like a RRS.
This one also has different wheels than the prototype that was shown about a month ago. These ones look more like 19's or 20's.
I think you can see the size on autoblog. They looked like 255/60/20.
bbyer
Alberta
I hope the wheels are no larger than 18" with maybe 34" or 36" rubber.
For me, a rough road vehicle should have lots of rubber between the rim and the surface.
I will get a Jag if I want a race car.
manoftaste
Muffler/exhaust pipes still running under the control arms? Ridic. C'mon LR, really, whats the deal at your joint?
Should have come up with a solve by now as its been well over a decade since this unfinished part of the design was first introduced to us when the chassis had gone independent suspension setup.
Exhaust pipes running under the control arms in a Toyota Camry? Sure no problem. In a Range Rover? Not ideal, but we all know what the real intended use of that 100k+ model is, so its ok. But in a vehicle supposedly being designed and proudly marketed for off roading duties? No.
That was one bad thing in the LR3/4 that stole quite a bit of its real ground clearance under the rear diff area. If Nissan can solve that problem, so can Land Rover.
LR, please work harder vs finding work-arounds.
You sure about that? I don't see any exhaust running lower than an A-arm.
Strange. Looks like a different exhaust setup. On the 4 door, looks like there are two rear mufflers, but only a twin exhaust tip on the port (U.S. driver) side.
On the 2 door, looks like its a single, larger muffler, with single exhaust tips on each side.
Wonder if it's two different engines, or a newer revision of the exhaust?
TeriM
