3K oil change intervals for our LR4s?
Troy A
San Francisco, CA
Like most I settled on 5000-7500 miles. Did it at 5000 miles after a 2000 mile desert trip, otherwise, 7500. I do know that Paul Marsh (Marsh 4x4 Adventures - he has supported a number of Mac Mackenney's expeditions in Siberia and the Sahari as well as done a huge series with Andrew St. Pierre White) is a huge fan of 3000 miles /5000 km but that's usually for expedition / overland vehicles in consistently arduous conditions of mud, sand, dust, and extreme heat or extreme cold. Mine is at 80K now (2012) and my Blackstone Labs report came up "very clean, with no issues" at 78,000 miles. I'm pretty much leaning on staying with the 7500 at this point.
I had not seen @umbertob's post about DIY but I'm not surprised! :)
Quijote
Metro Boston
I had long been a believer in the 3k oil change, but that was with conventional oils that were more prone to sludge engines. I do think the only reason your owners manual recommends 1 year or 15k miles is for marketing reasons. With full synthetic Castrol every 5k seems to work great.
My rule of thumb back since college in the late 90's was to cut whatever the manufacturer's recommended interval was in half. My first car, a 2003 BMW 330i ZHP required 15k intervals on BMW synthetic. I cut that in half and did my own oil change in between the free, scheduled maintenance intervals.
Fulltimesav
Northern CA
I used to be a mechanic once upon a time for an independent shop. It sounds like I'll have the minority opinion here with some caveats. That said I don't think most have bad advice in this tread. IMHO the best thing you could do is switch to conventional oil and change every 3k from the oil pan. Mose people don't want to spend the extra money and time so they do the next best thing which is every 5-6k with Synthetic. This is the next best thing.
The way it was always explained to me is that is the particulate that gets trapped in the oil that you need to get out of the system. While it's true that synthetic oil cleans better and retains is structure better than conventional, keeping the particulate matter in the oil longer is less ideal then getting it out of there sooner. If you change every 3k in 3-4 mo intervals you won't get sludge buildup that people refer to. Conventional oil also leaks past seals less then synthetic. Again, you can save some money and time if you want to do the next best thing and stick to the synthetic schedule mentioned in this tread.
As for changing the oil from the top, I'd personally never do this because the particulate falls to the bottom of the oil after the engine is at rest. If you pull it out from the top you leave that particulate at the bottom which is the point of the oil change and less ideal. Either 5-6k syn changes or 3k conventional changes will likely serve you well, but I'd caution you from changing every 10-15k like the dealership recommends. That's kind of crazy IMHO. As someone else said earlier, I think they give those recommendations for marketing purposes and the fact that they usually only have to make the car last as long as the warranty. Then they don't really care what happens to it. Talk to 3 mechanics and you'll get 3 opinions as the old saying goes :)
ttforcefed
I had my mobile1 tested after 15K miles...was clean and i cld have went longer. i did 15k mile intervals until about 60k miles and now i have been doing 7,500.
For the love of all things holy it is Mobil, not Mobile. Mobile is a place in Mississippi.
