Rijidij Rear Tire Carrier
Michael Gain
Clarksville, TN
Since I finally got the fuel issue sorted, I finally installed my rear tire carrier.
It fits pretty tight to the body, but with enough room for recovery gear to mount
From the rear, you can see that it sits pretty high, but that is to ensure that it does not interfere with the backup sensors.
Nice stainless steal strike plate and latch channel
And super strong spindle and bearing assembly
Finally, I like how the tire mounts, as there are provisions for a lock, and there is space for other goodies to strap to the mount, or the brackets with the nuts (do not know what they are for, but could probably use them for something)
Michael Gain
Clarksville, TN
From inside, you can see that rear visibility is a little restrained, but not too bad
the backup camera works well (passenger side view is essentially blocked, but that is what mirrors are for), and the parking sensors still function
Overall, I'm very happy with the product and word be happy to answer any questions
Stuart Barnes
Los Angeles
Looks like a good product. Just remember that this will add another 176 lbs to the weight on the carrier if the tank is fully loaded.
(Assuming the specific gravity of the fuel is .77kg/ltr)
Weight would be similar to having a dual swing out with 2 jerry cans in the rear. BUT you're right, it'll question how heavy duty the single spindle is to carry a full size spare and 13 gal fuel tank.
Stuart Barnes
Los Angeles
If they say it’s man enough Then it’s an option I’d Seriously look into
Michael Gain
Clarksville, TN
Very interested! Can you share a picture? How annoying was running the wiring?
FYI. I mounted a new Kenwood camera to my spare tire carrier and wired it inuin the factory wiring harness. It works perfectly and gives you your panoramic view back.
Thanks, brother!
Looks great and the review covered practical features and issues. Also digging the Rhino hitch.
https://rijidijoffroad.com.au/products/discovery-3-4-swing-away-wheel-carrier/
I got it right from the fabricator. Took about 6 weeks to receive and was about $1300 (shipping included) after the exchange rate.
I would think that that tank would mount pretty well to it, as the piece where the tire mounts is removable. The tank should easily slide over the post and then be sandwiched by the adjustable tire mount piece.
Where'd you source it
Michael Gain
Clarksville, TN
00Jam
