LR3 BMS Reset for Battery AGM Charging
Have you had dead batteries or charging issues?
  • Yes
    Votes: 2 100.0%
  • No
    Votes: 0 0.0%
  • Total voters
BendRover123
USA
Quick question on battery change do I need to run a BMS reset?
Also AGM batteries need 0.5Volt roughly higher Voltage for charging than say Gel, or Regular Lead Acid Batteries, can the LR3 charge AGM batteries reliably? Is it designed and are factory batteries AGM or are they regular batteries?
douglastic
I don't think there is a "reset" that I am aware of
I have run AGM for just over 2 years now, after 2 dead interstates (each died before year 2) all H8 size
From day 1 on the AGM, I chose to supplement with a battery charger 1-2x per month - Seems to be doing well so far
BendRover123
USA
Thanks Doug for confirming, yeah i think without regular external charging the battery every couple months i don't think the capacity on mine holds. I will keep doing the same i also installed an H8, the original stock size was H7 i believe.
BendRover123
USA
Update here I killed my H8 AGM because I learned later on AGM are essentially not compatible with LR3s unless you want to **** your batteries early use Regular Flooded Cell batteries 8)!
douglastic
What is not compatible about AGM?
What battery did you run?
Can you claim any warranty?
Mine is still going fine. Duracell platinum from sam’s.
Actually has outlasted each of the 2 previous Interstate lead H8 - each died before year 2 with no supplemental battery charger use.
remember5
I'm running Duracel Platinum from Batteries Plus and on my second, seems like the first one lasted about 4 years and this one is probably on year 2 or 3. I'll check the dates when it stops raining.
I've run an AGM for a decade. It's fine.
LR3. I think both my LR3s have AGMs in fact. I am not certain on the 2nd one because the PO bought it but that's what I remember seeing.
anglotron
I’ve been running an Odyssey AGM for the past two years without any problem at all. Interstate batteries never seemed to last. I have a short commute and I think it’s important to use a charger every other weekend to keep things topped up. I use a CTEK MXS 5.0.
