LR4 steering fluid leak
Kwakazaki
I have a 2016 LR4 HSE with 70k miles in great condition, but slowly leaking steering fluid, and wetness on the drivers side (US) of the engine. I previously owned a 2012 V8 from new that got to 100k, and never had this problem.... I also did a bunch of searches across YouTube, general web, and LR forum searches, all coming up blank. Anyone have any problems like this, and is there a common source and fix?
16FujiDisco
Nashville, TN
Following. I have the same problem as well. 2016 with 64k. It's very slow but happening none the less.
Michael Gain
Clarksville, TN
Start at the reservoir. It is attached to the driver side air intake. Just slide it out of its brackets and check the hoses beneath for residue, leakage, etc.
I've noticed my power steering fluid is low on my '13. I guess I should check for leaks too and top it off.
When did you last flush it?
Have never touched it. I've been meaning to change the diff fluids out (Transfer case has already been done) so I'll probably add that one to the list.
