Air Suspension Faults (2011 Discovery 4 Petrol V8 with 192000 kms)
tonyrover90
Calgary, Alberta, Canada
Hi Folks, hope you guys are doing well
The weather in Alberta was extremely cold roughly minus 45 Celcius degree which probably affect on electrical components? This morning I recognized my car was a bit lower on the left side (looked like accessed height which I've never used) then I start the engine then it raising normal, since the parking lot was bit offset on left side so I thought it should be a reason. After that, a yellow triangle warning light "Air Suspension Faults" while driving around 50km/h, nothing else recommended from message like "normal height only", checked 4x4 info there was no sensor faults at 4 corners and the light just stayed constantly while driving on highway. Fortunately, arriving to the office, completely parked then I checked raising, lowering & normal height which were working like normal :eek:, turned off and the light was gone away. Now I parked my car at a normal surface ground parking lot, left suspension at off-road height, scale clearance height at 4 corners and I will check again after work. So sorry guys since I'm working at a rural area without a GAP tool or a specialist that's why I could not give more information, but I'm really appreciate your advices. Thank you in advance!
P/S: My car just left repair shop yesterday after replacing leaking radiator and water pump :hmpf:
There will be no good advice we can give unless you pull the error codes.
If you want to monitor what it does after it sits for a while, you'll need to pull the EAS fuses when you park it. Otherwise, the suspension can auto-adjust itself, even when it's not running.
tonyrover90
Thank you for your advices. So is it still safe to drive until I have a chance to scan it?
If it's not telling you otherwise, it's probably okay to drive.
Chances are it's a compressor or a spring or a valve block. Hard to say without scanning it, and it would cost a lot more to fix all those things than it would to get a scan tool and fix the right thing.
