tonyrover90
Hi Folks, hope you guys are doing well
The weather in Alberta was extremely cold roughly minus 45 Celcius degree which probably affect on electrical components? This morning I recognized my car was a bit lower on the left side (looked like accessed height which I've never used) then I start the engine then it raising normal, since the parking lot was bit offset on left side so I thought it should be a reason. After that, a yellow triangle warning light "Air Suspension Faults" while driving around 50km/h, nothing else recommended from message like "normal height only", checked 4x4 info there was no sensor faults at 4 corners and the light just stayed constantly while driving on highway. Fortunately, arriving to the office, completely parked then I checked raising, lowering & normal height which were working like normal
, turned off and the light was gone away. Now I parked my car at a normal surface ground parking lot, left suspension at off-road height, scale clearance height at 4 corners and I will check again after work. So sorry guys since I'm working at a rural area without a GAP tool or a specialist that's why I could not give more information, but I'm really appreciate your advices. Thank you in advance!
P/S: My car just left repair shop yesterday after replacing leaking radiator and water pump
