Brand New JLR Cooling System
M32H32IS
Texas
Puked coolant less than 10 days after replacing everything with new JLR parts at a well respected Indy shop.
*** is going on? Why would it just dump coolant? Got it home on a flatbed, vacuum filled coolant system & put 500 miles on it with 0 issues.
Is this thing haunted? Is this typical LR4 behavior?
2012 with 5.0
Balto
I had everything replaced, I thought anyways, then had a leak…..Was the thermostat that the shop did not replaced when they did everything else.
2012 with 5.0
Where did it puke from? I am betting air bubble from the work.
Salanizi
Kuwait
Probably air bubble, did the mechanic let the system air out before closing the system?
Sounds like an air bubble for sure then. Sounds like you got it sorted but in the end had to do it yourself.
