ARB Fridge
CRYA
Napa Valley
UHMW ain't cheap. If you go with the 1/2" plywood you'll probably want to use T-nuts. 1/2" isn't going to have much holding power with a screw.
I used t-nuts and everything is secure. I’ll try and snap a pic of my creation a little later.
CRYA
Napa Valley
Ok so here’s my homemade attempt at a half plate thing. It was going to be a temporary thing but I’ve not fine tuned the box. Anyways. I used t-nuts on the bottom and used longer hex button head screws to bolt the plate through the left side tie-downs. Headed out this weekend for a last-minute overnighter.
Or you can just remove the second row middle seat and it'll fit in there perfectly. I have an Engel MT45 that's strapped there full time and I can grab a cool beverage from the front seat.
My ARB has been in that spot for years. It is literally perfect for that use. Functions nicely as a table/arm rest for rear seat occupants as well. I designed my sleeping platform with a hinged lid that still allows access to it when the platform is in place. Several years on and I would not change a single thing about that mod.
CRYA
Napa Valley
That’s definitely a convenient setup if your use case allows. For our style, we need it in the back given all the in and out. Also seems easier to access maybe then leaning into the middle at camp to fish stuff out for meals etc, but you guys can speak to that. What’s awesome is that these trucks offer so many ways to customize to your preference! That’s a clean setup for sure!
powershift
Nevada
That is a nice setup. I started keeping my refer in the back and found that even with a 4" insulated air mattress, the refer vibrates through the seats. To fix that I set it on a pillow and 2nd air mattress to isolate the vibrations. I'm curious if you sleep in the cargo area and if so do you feel the refer vibrations in its mount?
Jarik
