Troubleshooting coolant vacuum fill failure
Rendak
Atlanta
Hey folks. I’m at my wit’s end with the very last step in the comprehensive cooling system overhaul on my 2015 LR4 with 86k miles that I’ve been doing following txfromwi’s extremely helpful video on YouTube.
My problem is that I can’t draw a vacuum greater than about -5 inHg. I’m using the popular OEMTOOLS 24444 Coolant System Refiller Kit hooked up to a Porter Cable C2002 pancake air compressor and I’ve followed the directions in the manual as well as watched videos online to make sure I’m using the coolant refiller kit correctly. I don’t think my air compressor is leaking air through fittings, but I’m not sure I know how to check with the coolant refiller kit. I’ve got another coolant refiller kit coming in the mail to see if the one I’ve got is a dud. And I’ve triple checked all the coolant hoses that I can think of on the LR4.
Anything else that any of you can think of as to why I’m not getting sufficient vacuum?
Thanks in advance!
Rover Range
Texas
I would fill the cooling system, then do a pressure test.
That way you can see where the coolant leak is.
Using WD40 to lube the o-rings is a no no. Some of the o-rings in the cooling system don't like WD 40. That would cause the o-rings to swell up and leak.
powershift
Nevada
I've never tried vacuum filling. How does that work? For my pressure test I used the harbor freight hand pump coolant pressure tester and it found a leak.
powershift
Nevada
Here's a good video of the tool I have.
That is trick. Not sure if I would trust it though. I like the old school way where you burp it. I'm curious, if that tool is shows there is a leak because it can't hold pressure, doesn't that mean you are adding air into the coolant system?
ugmw177
Charlotte NC
i always vacuum fill my 2011. You must have a leak somewhere or the tool is not engaging properly in the bottle opening to seal up properly.
scapistron
Massachusetts
With the supercharger intercooler vacuum filling is the way to go.
If your vacuum filler is pulling hard enough to collapse the large coolant hose you're doing well.
Rendak
Atlanta
Thanks for everyone’s advice so far.
For these kinds of vacuum fills, do I need to be thinking about any other sources of leaks other than the rubber hoses or do I need to be considering things like the seals between the intake manifold and the engine block, the PCV valve, and the seal between the top of the supercharger and the bottom of the intercooler?
And just of a note of some progress: I got another vacuum fill kit in the mail and set that up and now it’s pulling -10 inHg. So I thinking maybe the air compressor is actually the problem. I’m gonna borrow one from a neighbor and try again this evening.
None of the seals you mention (intake manifold, PCV, intercooler/supercharger interface) will make any difference to your vacuum fill. Only the coolant lines and passages, which includes intercooler itself radiator, water pump, head gaskets, heater cores, etc. If it’s not your compressor, the only way to find the leak is to get it pretty full of coolant and pressure test the system. That vacuum filler might be able to do a pressure test as well.
You mentioned that you did a pretty complete overhaul on the coolant system. A few common source of leaks on reassembly: (1) front crossover not seating properly into the block - sometimes a little piece of the old pipe is still in there. (2) the oil cooler inlet tube that connects the back of the water pump to the oil cooler. There are two o-rings on this pipe. As I recall, one comes with the pump assembly, but the other does not. Some people have put it back together with only one of the two o-rings. Others have just had the little plastic pipe/o-ring not seat properly when installing the pump. (3) I find the throttle body heater hose is easy to forget. Just thought I’d mention it. Good luck.
