ugmw177
Did the lr4 every have overheating history?
Probably a good guess. Land Rover designed these vehicles to make it easy to blow engines. In Utah its thirsty, in the Mohave it is not. My last change went 6k miles changed February, never added any oil and the level was full before I changed it yesterday and I've been in the Mohave the whole time. I go up a 7% grade all the time, the speed is slower though vs Utah.This is all from me just really thinking about this, but i’m now thinking after my last two oil changes i pulled out less oil out of the engine than what i was used to seeing in my mityvac. I definitely wondered about the oil consumption and figured i’d keep an eye on it. Usually i do a change every 6 months and do maybe 1-3k miles of driving? However, this last oil change to failure date has been 7 months and like 6K miles… I did a lot of driving this period due to the summer and got lazy to change the oil in august. I’ve been using amsoil and i use genuine filters so figured i’d be fine. Do you guys think i was maybe burning up this oil quicker than i initially thought? I had no codes or smoke out the pipes. Don’t recall any soot on the tailpipes. Another thing when the engine went i noticed the oil that came out of it on the ground looked like maybe 3 quarts? It definitely was not 6-8 quarts of oil. Then again i never got an indicator that my oil was low on the menu screen? i’m wondering if i was just super low on oil and in combination with driving it hard….i was gunning it up and down i’m not going to lie. I had it maybe 5-6K at some points between some shifts here and there. I do this once in a blue moon. Usually i am gentle on the pedal. How much oil do you guys usually consume between changes?
