Car stuck in extended mode after replacing compressor
Sonny_Dd
Bosnia and Hercegovina
Hello everyone.
My compressor died, so I got a new one and now the car is stuck in extended mode. When I try to lower it it get the The car is in extended mode and reset suspension when cleared of obstacles message.
Tried driving above 20kmh nothing. The new compressor is also constanlty running.
Rover Range
Texas
Check that the air lines are in the correct positions.
Slightly loosen the air hose that goes to air reservoir. Let the vehicle drop.
Retighten the air hose. Close all the doors and start the vehicle.
See if it reacts normally.
Sonny_Dd
Will try that. I also noticed on the 4x4 display that one of the white dots under the tyre is blinking red. What does that mean and does it have something to do with my problem ?
