Strider95
Update. All codes fixed. My only standing problem now is the rear temp sensor. sensor 1 (rear) showing 302 degrees and .07v. Testing the harness pins I have 3.5v and 12v. According to the wiring diagrams the rear wires should be yellow and green/brown. I have solid green and grey. The front temp sensor (2) colors are correct to the diagram. Diagram shows temp sensor 2 yellow to pin 40 at ecm, and green/brown to pin 13. I have continuity between yellow and 40, but not green/brown to 13. Diagram shows temp sensor 1 yellow to pin 68, green/brown to 13. My green wire on sensor 1 has continuity to pin 85. My grey wire has continuity to a pin on the 18 pin connector near the ecm. Which continues on to the ecm fan. I have continuity between grey at sensor harness and ecm fan harness. At this point, I’m lost.
