scapistron
I'd assume there's knockouts in the firewall for the RHD version.
gine).
Question for @scapistron : Are we talking about a RHD (i.e. UK) or LHD (i.e. NAS / LR4)? I am only going to speak for the LR4, which is what I am driving. RHD would be a rather different animal (because a UK variant would both RHD as well as the Discovery 4 TDI V6 engine)....I'd assume there's knockouts in the firewall for the RHD version.
Regarding where to push wires through the firewall on the passenger side (so again – I am referring to a NAS LR4 / LHD): you can make a cut in the large rubber grommet / seal which services the large wiring loom going to large series of panels behind the glove-box.Errr….i don’t suppose anybody knows a pass-through in the firewall on the passenger side?
Thanks!Hi LR Joe, just note, ordinary isolators will not work with your SMART alternator operation.
You will find that if you replace the Traxide unit and you use a fair bit of the auxiliary battery's capacity, you can only use a DC/DC device to get the auxiliary battery properly charged.
I ended up going through the firewall on the passenger side. I made a hole, and put seals on it.Bumping this thread. I’m looking to route a wire for power all the way to the back. What route did you end up taking? I don't have a preference on driver or passenger side.
I've been thinking about drilling a hole to run a beefy cable to a Victron DC-to-DC charger for a lifepo4 pack. What gauge wire did you use and what seal was used?I ended up going through the firewall on the passenger side. I made a hole, and put seals on it.
