2000 Disco 2 Tail lights
robdog
Hello, just asking for a lil' help. I believe that the tail lights are associated w/ a relay in the Engine fuse box. Unfortunately the owner's manual does not address relays. It addresses only the fuses. Help please on this issue???:help:
joey
What is the issue? Makes it easier for us to help if we have more info.
robdog
Well, the tails do not operate when the headlights are on. They used to. I believe the issue is w/ a bad or missing relay, but I don't have any info about this subject. The manual only talks about fuses.
joey
sounds more like a bad headlight switch... do the dash lights work? Center console lights on?
robdog
Yes. Now is this switch in the Engine Fuse box??? I thought it was called a relay, but I don't know.
joey
When I say switch I mean the actual headlight switch on the steering wheel... This is a known issue with rovers and may be your issue...
Normally when both tails light do not work the switch is the issue, but have you checked to make sure the bulbs are just not bad.
robdog
Thanks for the tip. I will check this out.
tragic1
