maintenance history since new 2013
ttforcefed
well here is what 15k mile annual oil intervals gets you - from blackstone oil analysis:
"This is a very clean first report for your Discovery. Wear metals are a little lower than we've found on average from these 5.0L engines, and you ran the oil pretty close to the average interval of about 7,900 miles. That means your engine is wearing a little better than the other ones we have tested, and it will have no problem with an extended oil change interval. The TBN of 2.4 shows some additive left for more use (1.0 is too low), the oil filter easily kept up with insolubles, holding them to just 0.1%. Resample in about 9,000 miles to start wear trends."
Hence my decision to swap oil every six months and filter yearly. I probably should back my oil off to yearly as well.
ttforcefed
Based on the analysis id easily go back to 15k mile intervals...
Fuji4
I think I’m in on that one. Only issue for me is I usually get my tires rotated at oil changes. Which would push that out
ttforcefed
here is what ive done since my OP
12/7/18 85,534 - right front heights sensor and strut 2,067
1/2/19 86,684 - oil change, spark plugs, parking light 968
1/7/19 87,432 - control arm and shock 1,535
6/17/19 94,080 - Oil change, EBC green front and rear pads 500
9/4/19 97,500 - Trunk actuator 300
10/2/19 98,580 - Install new running boards 1,200
my total since delivered new in oct 2013 is $16,210. as i wld have expected, aside from tires the brakes and suspension are the biggest costs.
Fuji4
112k upper control arms and main drive pulleys and tensioner
ttforcefed
Slight valve tap sound so doing the chain and tensioners also
ttforcefed
12/12/19 102,045 - oil change
01/04/20 102,650 right front sensor $180
07/08/20 107,194 - oil change
11/16/20 111,900 - battery
12/15/20 112,608 - oil, air and cabin filter, $700
06/15/21 118,000 - front and rear pads and rotors, tires, oil $3,135
10/14/21 123,367 - front lower control arms and joints, alignment, oil $2,284
03/01/22 126,085 - water pump, coolant system, timing chains, drive belts, spark plugs, oil cooler, thermostat, AC service $7,593
09/01/22 133,000 - oil
