2008 LR3 HSE Transmission Shifter Change
KenS
Edmonton Alberta
Good morning.
I changed my transmission shifter due to a failure and now it will not go into drive. Reverse works okay but truck will not move in drive at all.
Any ideas?
Thanks
06Rover
Good morning.
Any ideas?
Thanks
Good morning.
Any ideas?
Thanks
Good morning.
Any ideas?
Thanks
check the shifter linkage, May have came loose when swapping out the shifter....
Yockstar
Washington, DC
You reference your transmission shifter....? Would this be the gear shift assembly inside the cabin of the truck or the gear linkage that connects to the valve body, right at the transmission...?
My thought is that depending on how you did the change out, there may not be a proper alignment at the gear linkage. Here is a link identifying the gear linkage, in case this make any relevant sense.
