2010 V8 tinny rattle under acceleration
Mozambique
toronto
So, recently my 2010 V8 with 210k km had developed a tinny rattle sound mainly evident under acceleration. It sounds like a rotor dust shield rubbing, or a loose heat shield. I wondered about exhaust muffler baffles being loose, but no noise when revving in neutral. I haven't had a chance to have a good look underneath yet, but was wondering if this rang any bells?
Mozambique
toronto
Ha!
Never guess what it was.
The pipe coming rearward out of the middle muffler has a flange on it where it goes it to a flex pipe. The flange had rusted through leaving a loose metal ring encircling the pipe. On acceleration it was bouncing around. I snapped it off using pliers. Annoying rattle solved!
Mozambique
toronto
Hhhmmm....... thought the noise had gone away, it hasn't. All heat shields seem secure.
jlglr4
Northern California
The transmission heat shield bracket is a common problem. Mine has cracked three times (although I repair it with a welder and I’m a terrible, terrible welder).
It will feel secure when you try to move it, but it’s the bracket underneath that develops a crack and will vibrate when the tranny is under load. Take a mallet and rap on it a few times under the car. If it’s cracked, it will start to vibrate a little and make that tinny rattle sound you’re hearing.
Mozambique
toronto
Found the issue!
First hint was a silver band around the drive shaft (front to rear). Turns out the rubber diaphragm through which the driveshaft passes through at mid-way point had a tear in it. When accelerating it was moving and rubbing against a bracket. Quick fix was using construction glue to seal the tear.
Have an Amazon $CAD299 replacement drive shaft ready to go on. Simple unbolt and replace. Will see how long it lasts.
Ditto got a $CAD 99 replacement front wheel bearing hub from Amazon (both items A-Premium brand). It's a 6lb lump of metal for $99??? Ditto, will be interesting to see how long it lasts vs. $270 aftermarket one also of unknown quality.
scapistron
Massachusetts
Bolts at the transfer case and rear diff are supposed to be single use. Although I don't think they're actually torque to yield. If you're reusing the original stuff be liberal with the blue loctite.
