60k service
GSMblue
Just a note that may help others working out costs.
Service - $480
Hood switch - $40
Front rotors and pads $500
Biagetti
I'll be approaching 60k here soon, so thank you for the heads up. What is included in the $480 service?
Be real careful, cause the service recommended by Rover are not all that is needed, you also need the tranny, both diffs and the t/case fluids changed. Rover will tell you that this is not needed, then ask them about the high failure rate because of no servicing per the owners manual.
GSMblue
I will upload the inspection/service report stuff tomorrow. Glad it helps someone!
GSMblue
It would appear they did not do the diffs or the t/case fluids....
GSMblue
Thanks, I will get the fluids done when I take her in for spark plugs in October.
If you are thinking about having the dealer do it be aware that they will tell you it is not needed, but believe me, it is
rnzslzr
