95 Country Lwb
J
JASON4X4
I just got my first land rover and the drivers power seat, power mirrors and cruise control doesn't work. I just ordered a service book for it but if anyone has any info that might help please let me know
thanks
Power seat probably the switch, same with mirrors. Cruise is more than likely a vacuum leak.
J
JASON4X4
the seat switch isn't getting power and i can't find a fuse I didn't check the mirror switch yet
Could very well be a common fuse or ground... let me check the manual.
NOT sure if this helps or not... not much is listed for the RRC in my manual... unless you want to start searching relay's
ELECTRICAL SEAT FAILURE
NOTE: Carry out following procedure if
seat failure occurs with seat obscuring
fixing bolts.
1. Check 30A fuses and courtesy lamp fuse B2.
2. Disconnect 9 way connector between seat ECU
and motors (memory seat). Power motor from a
seperate battery source.
3. If partial failure occurs in forward and reverse
travel only, change drive cable as required to
move seat to desired position.
4. If 2. and 3. not possible, move seat by driving
cables manually.
J
JASON4X4
i didnt find any bad fuses. I pulled the plug for the motors and got the seat to move with my battery charger. i think that to box under the seat is bad.
Does the box under the seat control the mirrors also? i havent had time to check the cruise yet
PE_in_UAE
