96 Disco Problems (w/fault codes)
97rangeroverP38
I just picked up a 96 Discovery and wanted to check my mechanics recommendation.
1996 Discovery
120,000
Issues:
Misfires at idle & when revving to about 2.5-3 RPMs
Smoke comes out of air vents & behind vehicle when I am accelerating
Leaking oil
Fault Codes:
P0300, P0306, P0304, P0303, P1316, P1314
Mechanics Recommendation:
Change valve covers
Change ignition cables & spark plugs
Also is there anything I should be aware of if I am to buy the parts for the above and have a friend work on with me (a mechanic that is not used to Land Rovers)?
Thanks
jastutte
your mechanic's advise is a good place to start.
try some kingsborne 8mm wires and the cheap champion plugs.
i wouldn't use the OE 7mm wires. when i went with those my fuel mileage actually dropped.
i couldn't find the link i used to have to the obd2 codes or else i would have posted it. hope someone else has it.
valve covers are an easy thing to do. might as well just throw new valve cover gaskets on there.
PE_in_UAE
