98 Discovery runs rough? Code P0300
S
squeakyclean
1998 LE Discovery \ washed the motor and it will dont drive now.75k miles and it runs rough. changed plugs and wires. pulled code P0300 plus 1317 1316 1314 1313?
Sounds like either a) you got water in the air filter, or b) the crank sensor got wet.
97rover
check Coil packs did the same thing burn't 2 out. Can't buy individual have to buy whole rail from dealer $950.00 us. Or go to a junk yard $650.00 us
97rover
thanks your right I didn't search didn't have time. But will take time in future to save $300.00 bones
97rover
code list
A complete list of codes can be found at
www.robisonservice.com/servicedep/rover_obd2.asp
and at
www.toublecodes.net/landrvr/
p0300 random/multiple cylinder misfire detected
1317 abs rough road line low fault
1316 misfire excessive emissions fault
1314 misfire catalyst damage fault bank B
1313 misfire catalyst damage fault bank A
Check you CAT sensor and Bank A is the right side of engine as you are looking at it and Bank B is the left
tragic1
