AC refridgerant quantity?
discoman
Does anyone know how much AC refridgerant goes into an 96' D1??? My disco does not come equipped with rear AC so I will only be charging the front system.
I would have to look that up, but it should tell you under the hood. At least it will let you know how much pressure it should have while running the A/C at the low fill side.
Per the book it is 0.9Kg = 0.9 kilogram = 1.984 160 36 lb, lbs = 32fl oz
Sid1577
