Air Suspension
Theil6
Hi, I have 2004 Range Rover and when I come out to the Vehicle in the morning it is sagging on the front end. It seems the air is leaking out. Is this normal or should it be repaired?
Thanks for the help
Thomas
socalrovershop
very common normal wear on air springs. rec replacing air spring assembly
NhudeST
What's the mileage on your RR? Reason I ask is because my R front airbag suspension bag gave out around 87k. Also, if it happens to be the front airbag suspension system which are no longer serviceable, I would suggest hitting up Arnott Inc. I purchased mine from them about 2 years ago around this time of year. They even provide instructions on how to install them yourself. Good luck with that man.
socalrovershop
yes arnott have good air springs i actually started selling air struts assemblies to them so they could rebuild them about 3 years ago. its a brand new bag but a used strut. they also offer a heavy duty bag you put on your self but its about a hundred bucks more than a assembly.
Disco2TrailEdit4
