Bluetooth Phones?
K
kevinr
my treo 650 works fine with my 2006 range rover supercharged with the exception of the addresses not transferring...that is not a big deal to me
W
wimvandorst
My Treo 650 works fine on Bluetooth in my Land Rover.... Defender. Okay, I put in my own Parrot 3200 carkit.
Met vriendelijke groeten, Wim van Dorst
M
Mitch
Storing numbers
I tried to store phone numbers in the RR memory by using phone button on steering wheel and it would ask me the name, the number and would confirm both, then when I would answer yes to continuing with the process, it would say this has been cancelled. Does anyone know if there is a way to trick the system in to accepting numbers into the RR's memory this way when you're using a non-approved phone? Or is there a firmware/software upgrade that allows us to use the memory with non-approved phones?
Regards
Slytrellis
