Clutch problem
Niko
Hi
I am an owner of LR Discovery II (2002) TD5 manual gear box and I have serious problem. Unfortunately in my country the technicians from the authorized service are incompetent or let say incapable to help me. So the problem is following:
When I change gears for ex. from second to third when I push the clutch pedal in the beginning the revolutions of the engine start rising with about 500/1000 and then star going down. I have been told by the mechanics of the service to change some kind of module which controls the distribution of the revolutions of the engine during the change of gears. I did it but the result was nothing.
I would like to mention that I bought my car with a damaged roof and I believe that this car has crashed and has stayed upside down. In the beginning I had to remove the air from the clutch hydraulic system because the pedal was not working. Now it is OK but I have this problem with the revolutions. The computer is not marking any mistake and that is why nobody knows what really the problem is.
I would be very grateful if somebody can give some advices or to give me direction where this problem could come from.
Thank you in advance.
Sounds to me like you need to reset the parameters in the ECU (this requires someone with the LR Tech computer system) either a dealer or a good LR mechanic. Even after you change a part on a newer LR if you do not reset the system it will still think the old part is there.
BCNJ
