Coolant Level Question
Medge222
Rumson NJ
Newbie over here! My 2016 LR4 HSE Silver Edition was serviced in November for an oil change. I purchased it in of June 2020 from a Land Rover dealership. The coolant level alert is telling me it’s low, but how can that be? One doesn’t go through coolant that quickly right? Based on experience, do you think it could be a leak or a sensor issue?
Thanks so much in advance. Attached a picture of her for fun.
DaytonaRS7
Have you actually looked at the truck to try and diagnose? a leak or low coolant should take all of 10 minutes to determine. If its neither of these, could be a sensor.
jlglr4
Northern California
The coolant low sensor just measures what is in your reservoir. So, check your reservoir. If you have coolant to the specified level and the warning still shows - that’s a sensor problem. Easy fix.
If your coolant is low and you’re sure it was checked in November, then you have a leak and you need to find it. Check around with a flashlight for the orange fluid (maybe dried residue). Leaks don’t always spill out all over the floor.
One piece of advice - do not ignore this problem. You will destroy your engine if you run it without coolant even for a short amount of time.
anglotron
I think it’s less likely to be a bad level sensor, although it certainly could be, and more likely to be the float in the coolant tank that stops floating and thus giving false readings. At least this has been my experience.
Medge222
Rumson NJ
Turns out I had a cracked pipe, and not a sensor issue. Thanks for the helpful advice. I won't ever ignore a coolant alert again!
Stuart Barnes
Los Angeles
Glad you got it sorted.
I’ll ask for everyone else, which pipe? Are you able to get photos of the cracked pipe, or a part number?
Also cost to repair?
Keep on roverin
stu
