CV Joints
Ump
I have a 97 disco with 197000 miles. I recently purchased the vehicle and have replaced front driveshaft & U joints. I started changing fluids and have changed fluids in both diffs.
I checked the CV and all I could see is grease. The rave manual shows that the CV's should have 90w gear oil. The question is should I add 90w to the grease or add grease only? If grease only, what grease? Thanks, Wade
Disco Mike
First, as part of the service, you should, especially at that mileages, inspect/clean and replace as necessary all 4 wheels hub bearings. You must also get the preload reset for your swivel joints. As for the grease, Rover , long ago up-graded to a special grease instead of the old gear oil.
Might want to down load a free Rave CD, shop manual, so you can find your way around your truck.
Ump
Thanks for the reply DiscoMike. I was getting my info from the rave manual. It states the following "The wheel bearings are lubricated with grease and the swivel housing and differential with oil." When I pulled the plug to inspect the swivel housing the only thing I could see is grease. So I was a little confused. Do I need to put the NLGI-2 multipurpose grease in the swivel housing? Maybe I am missing something. Thanks again for the help. Wade
Maddie
Ump: there is a special swivel housing grease. Sold in 370 gm bottle. Not as viscous as wheel bearing grease. I'm a purist that is resisting using it as I like to drain and refill with 80/90 oil. Call me stupid.
Maddie
PS: the part number for the swivel housing grease from Atlantic british is stc3435
