Electric fan/water pump
Does anyone know how difficult it may be to install an electric cooling fan or water pump?
Would it be worth while?
Any feedback would be appreciated, thank you.
Water pump on a 98 about 2 hours for the average person. If the old one is bad, replace it, otherwise it is a waste of time.
Electric Cooling fan, you have to find one that fits (this is the hard part, unless you want to spend big money on the one designed for the Disco from the UK.
Electric fan will save you 15 to 20 HP (I Should say give you) and help with fuel economy.
I found a few different ones on jcwhitney.com along with the waterpump i just have to measure what kind of space i'm working with. now how would i find out how long my new serpentine belt... and would i be able to remove the stock fan or should it be left in?
blownf150
just take out the stock fan on a d1 there are bolts holding the pulley on i got my fan from a c6 vette i had sitting around just took some scrap metal and made a shroud and put in a temp switch and a man override switch so it wasn't a prop in some of the deep creek crossings we have down here the factory fan can be alittle dificult to get off there without the fan wrench to hold the pulley from spining but can be done pm me if you need any hepl
