Headlight washer fix needed
horatio8
On my 2013 HSE Lux, every third time you spray wiper fluid, it's supposed to spray the front headlights ("headlamp power wash," as it's described). The problem is the spray overshoots the headlamps and lands all over the hood. Is this something I can adjust/fix myself, or do I need my dealer to take a look? Thanks.
Take the thinnest needle you can find and gently work it into and around the two nozzles in front of each headlight, to clear any debris diverting the spray pattern. Usually it's just some hard water residues or road grime partially clogging them up.
PALR4
Every single car I've owned with those miserable things has shot the stuff all over the hood. Drives me crazy when the car is clean. Just make sure the headlights are off, and the headlight washers won't work.
PaulLR3
Boston
Land Rover should do what Audi does - make the headlight washers part of a cold weather option package along with the heated seats & steering wheel. I love having the headlight washers in winter when slush and road salt build up on the lights and you can restore good forward lighting while moving.
PALR4
I'd like to see them to put in a separate switch for the headlight washers. The only time it's really needed is during winter driving at night... I used to be able to pull the fuse for this miserable little feature. :confused:
