Heater control unit PROBLEMS
jodyru
1999 Land Rover Discovery II .
My Heater control unit will not light up or display anything,yesterday it was working great. I checked all my fuses below steering wheel, and under hood.I installed another head unit known to be working from ebay,and still nothing. Any ideas???
Thanks for any help.
** Update**
I still have not found the problem.But I did check the voltage on the White plug that goes into unit and the top 2 pins at the top of plug the purple wire had 12 volts and the green with pink stripe only had 1 volt so I ran a 12 volt wire to the green with pink stripe wire and now the unit works. Still not sure why that wire was NOT getting voltage......
Vintage99
