HELP!!! Changed head gaskets &....
Phantomcanes
cylinder heads were rebuilt,due to a Coolant leak.
The truck ran fine before the work was done.
Now it will start but will not stay running- the alarm light also flashes(which it didn't do before either).
Any help before I take a baseball bat to it. Thanks.
Oh Yeah, it's a 2003 Discovery SE. It has 55,000 Miles on it.
Slam
Supporting Member
Supporting Member
I think the baseball bat trick should work. My buddy just had the same thing happen, but it also left a nice crack in the engine. It was also a Discovery II.
Make sure to use genuine gasket kits and new head bolts. No reason to go cheap there.
I heard it is a good idea to do an ATF flush before starting. Good luck!
Phantomcanes
Sad, All the bad things I heard about Freelander I never had a problem with it and I have almost 90,000 on it.
So, now that we have gotten past Freelanders, are you still having issues, if so, be specific, any codes?
rutherfordred
I too own a Freelander but i have never faced such issues it has 106,000 on it. I hope it continues to be the same as it is now.
PanKyiv
