Here Come The Gremlins
S
sjskarts
On my 94 Disco I have a strange problem when I shift from Drive to Reverse my radio turns off. This happens 70 % of the time. Is there something in the center console that might have come loose?! I know there could be a hundred things that might be causing this but I hope someone has had a similar problem and was able to rectify it. Also when I switch to th cd changer it blinks and doesn't play some times it even skips the changer option, but once in a while it actually works! Go figure any way thanks in advance for any help !!!!
ps I have a stock radio that might help !
Sounds like a short in a ground, but I don't know how shifting into reverse would make a difference.
S
sjskarts
Now its doing it when open the door , come to think of it my ppoch got his leash stuck under the passengers seat I wonder if there is a groung under the seats? It just realy annoying ! Thanks for any help
You may also want to check your battery, but the under seat ground my be a good place to check.
S
sjskarts
Is the such a thing as a ground under the seat ?? If so where should it be, I also noticed a green clip hanging under the dash on the passenegers side when I fillde with it the radio doesnt go off when I shift and the chime rings different (when you open the door) any ideas?! im going to try to take a pic and post !
Thanks for any help!!
tragic1
