Hub (brake disc) removal Discovery II
klaine1
take off wheel. take off 2 bolts to brake caliper body. take off 2 bolts holding caliper carrier. unscrew little phillips head screw on the hub (brake disc). turn steering wheel to better expose the brake disc. gently hit the brake disc with a rubber mallet from the inside out until it loosens from the 5 bolts. Then you will see the ABS sensor. :stupid:
