L
Len
I've had the similar problem on my 96' Disco that is discussed other places about hesitating or chugging, etc. associated with a bad vehicle speed sensor. I bought a new one and it didn't change anything. If I run with it unplugged the truck runs better than ever. I plug it in and it goes right back to the same.
When plugged in I've gotten codes that are similar to what I found on another site from a Chris in St. Louis (I think) that says: (although I didn't have it read by the testbook)
"If the MIL is illuminated with misfire codes P0300, P1316 and any combination of P0301, P0303, P0305 and P0307 stored or if the customer complaint is surging, hesitation, or loss of power at highway speeds, pay close attention to the freeze frame data, particularly engine rpm and road speed."
I've checked the wires as far as I could to see if they were melted or cracked. I've look at and checked fuses. I've removed and cleaned the Idle Air Control (stepper motor). Also, recently put on new O2 sensors. The catalytic converter is new within +/- 5000 miles.
Does anyone have ideas? Or with 113000+ miles and it it running VERY well should I just run without the speedometer and Odometer and forget about it?
Any thoughts would be appreciated.
Len
Len
