IID/Gap Tool
djatkinson
I'm trying to clear a code related to PCM-Engine Petrol. I've tried it, but haven't had any luck. The dash warning light is still on. The Gap Tool manual is over 190 pages long!
Thanks in advance!
The code is probably reoccurring and can't be cleared (or, more likely, pops back up as soon as it is cleared).
Just to be sure, go to faults > check fauls > then clear all.
djatkinson
Hi, Ryanjl,
I tried that; no luck. As you display in your ID: "Incredibly unhelpful".
Sorry I couldn't resist!! ;-))
jlglr4
Northern California
I remember reading that some codes cannot be cleared, but will go away once the underlying problem is rectified. I think some of the smog-related codes fall into this category. What is the code you are seeing that you can’t clear?
DallasLoneStar
Dallas, TX
OP, you realize that clearing the code does not fix the problem, right? If you clear a code and the problem hasn’t been fixed, it will reappear of course.
Jimmy Brooks
Pasadena California
Yup, could be a PDTC (permanent diagnostic trouble code). PDTC are often things like evap codes and your evap system sensors haven’t reset yet. it might help if you tell us the code to see if it is a PDTC.
