It was pouring rain last night here in Toronto. I parked my truck outside and when I got back inside my truck, I noticed the area around the airbag badge on the A-pillar was wet.. I knew it was my turn to get the legendary leaking sunroof.
Anyways from the research I had done on here and disco3.co.uk, I found out the "solution" to the problem, which is to nip off the end of the drain hose located behind the front fenders.
I had my friend put an air gun through the drain opening on the sunroof. At the beginning, the air coming out from the end was very weak. After a few more tries and some unknown debris hitting my face, my drain tube was finally clear.
The only negative in this process is that the passenger side air vent grille, which had its lower tabs broken off while I was trying to remove it. Can anyone post the proper steps to pull it off? I don't really plan to do this process any time soon, however I might want to buy a new side grille and put it on... it's now being held with the upper tabs as well as some silicone on the bottom.
I spent almost 3 hours with my hairdryer to dry the floor boards... I believe there might still be some moisture down there, but I will continue to dry it using the hairdryer... or if anyone can suggest any other quicker/more efficient way it would be really appreicate it!
