Lighter Electrical Port
Heem
On my 96 Discovery, it seems that the lighter "port" is bigger then on other cars - that is to say, my cell phone charger doesnt fit in there. It just flops around. Is this normal? Maybe it's a british thing? (I've only had american cars in the past) Is there an adaptor available so I can charge my phone or use a radar detector, or am I going to have to wire up a custom port for these devices?
thanks
-Jim
R
RoverDisco98
I noticed the same thing with my 98. Wrap some black tape around the plug and it will work
Moose
Supposedly there are adapters, but my suggestion is the same as RD98: Wrap a layer or two of electrical tape around the plug and it'll fit. The best thing to do is probably to get a 12v lighter outlet strip and then you can use the modified plug (with tape) more or less permanently with "standard" size outlets attached -- and you'll have more than one!
:biggrin:
Good luck,
Andy
Sam Grant
My Porsche is the same way, I used to use a small plastic adapter that fit over the plug and it would hold it great...I think I lost it though. Its loose but it barely ever falls out so I dont mess with it, eletrical tape sounds like a pretty good solution...
PE_in_UAE
