lug nut
dragan
Lug nut
Do anybody know what proper torque for lug nut on lr3 is
I replace brake yesterday and I have treble to take wheels of.
I broke lug wrench trying to get lug nut loose. How tight lug nut need to be
I use 100 lb-ft but I'm not sure if that is the spec.
USAFbuckeye
The spec is ~140 Newton meters.
Really? I was pretty sure Discount Tire only torqued them to 100 lb-ft.
mustbeaudi
I never trust the tire shops, so I always loosen and then retorque my lugs to spec after anyone touches the wheels. I keep a pipe length or collapsible breaker bar in each car for leverage on over-tight lugs. Worse situation would be stuck out on the road with a simple flat but unable to loosen a lug because some knuckle head over torqued it.
mustbeaudi
more lug nut torque specs and brake job specs
SPECS
Wheel Nuts - 140 Nm (103 lb.ft).
Anchor Plate Bolts - 115 Nm (85 lb.ft)
Guide Pin Bolts - 32 Nm (24 lb.ft)`
Brake Disc Retaining Screw (Torx) - 35 Nm (26 lb.ft)
Brake Hose Retaining Bracket - 25 Nm (18 lb.ft)
Front Brake Hose Union to Caliper - 32 Nm (24 lb.ft)
Rear Brake Hose Union to Caliper - 28 Nm (21 lb.ft)
Bleed Screw - 14 Nm (10 lb.ft)
Front - Brake disc thickness - NEW 27 mm, Service Limit = 24 mm
Rear - Brake disc thickness, NEW = 20.0 mm (0.78 in), Service limit = 17.0 mm (0.67 in)
Disc Run Out - must not exceed 0.3 mm
Pad minimum thickness 3.0 mm (0.12 in)
REAR
Disc diameter on Tdv6 325mm
Thickness new 20mm
Minimum Thickness 17mm
Run out 0.3mm
Pad Min thickness 3.0mm
FRONT
Disc diameter Tdv6 320mm
Thickness New 30mm
Minimum Thickness 27mm
Run Out 0.3mm
Min Pad Thickness 3.0mm
jjvd21
Is it safe to change out one (1) lug nut while the D3 is sitting on the pavement - not jacked up? Would this cause too much stress on the remaining lug nuts / wheel?
morrisdl
Not sure of the official answer, but I would not hesitate to swap out lugs one at a time without jacking. Ive driven around for weeks with one missing (state inspection mistake).
drzjoint
I would not do it. It takes 2 mins to get the weight off with a jack.
00Jam
