R
redrover
I have a '99 disco II with a major problem
Start up is fine, but engine wants to die right away. It will barely keep running and then after a few minutes rpm's steady out at around 800.
When trying to drive I can barely get it up over 15 or 20 mph and it hesitates badly, sputtering.
On Saturday - Have checked spark plugs - great condition, gap set correctly. Battery/alternator both good. Spark plug wires good. Plenum gasket replaced about 6 months ago. Tested vaccuum - about 11 @ startup, then immediately drops to 6, slowly working itself up to about 14 after a 5-minute period @ idle. At approx. 3,000 RPM (Holding throttle steady) it reads 16 & then drops to 9 - 10 about every 10 seconds. Has about 120,000 miles on engine. The problem of not going over 15 mph happened as of last night, after these tests. But, it was hesitating badly the last few days prior to testing, and have had an ongoing worsening problem at startup.
Any info would be greatly appreciated.
Sorry in advance I'm new to this.
