Cowinthefog
I have the 5.0 NA AJ133. Used block. I had the heads and block deck milled .015 total to flatten them. I also had the cylinders bored .020 over to remove light corrosion.
Question 1- What is the stock head gasket thickness? I assume I should get a thicker gasket to compensate.
Question 2- Does the overbore require a change in the cylinder size opening of the new gasket, or is it close enough to not matter?
Thanks
Thanks
