Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My wife's 2000 discovery is leaking power steering fluid right around the adjusting nut on top of the pump. Can I just remove this and put some thread sealane on it or what should I do?
I used some of the lucas stop leak for Steering. Best $8.00 ever spent on my truck. I may end up spending $16.00 though as it ate half of the first bottle waiting for the seals to swell.
if you are sure it is leaking from the adjust not and not running down from the fill tank, then you can replace the 'O' ring, but make sure the cheap clamps that hold the non-pressure line are not the cause of you issue.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
