Pre-wired heated seats w/o switches?
M
mrkersh
I have a 2004 Discovery II and I had the same question. I think that you can only install those with leather seats. Never did get an answer back from Rovers North, British Atlantic, or even Land Rover themselves. Good luck.
L
LR2000
Leather seats
I do have leather seats, but also have not received a reply from British Atlantic, but will querry the service department at my LR dealership when I go in next.
Quickest way to find out it remove the window switch panel... if you find two plugs not pluged into anything... you have seat heaters.
F
FREESTYLER
its kinda funny lol but i already done that . i bought the car with no heated seat switches switches . but yes just like joey said open up the cover on top of the window switches ( very easy to do ) and there should be 2 plugs there . buy the kit , plug them there and ur all set ! another way to find out is that if u have leather seats and the woodden trimming on the door and over the glove box , then ur seats are prewired and ready to go . mostly all D2's are prewired except the SD models and the ones with cloth seats . good luck !
L
LR2000
Well, unfortunately I don't have wood trim and I do have the SD model. I haven't had a chance to check for the extra plugs, yet. I was out earlier trying to fix the turn signal when I blew the fuse. Why can't Land Rover include a few extra fuses!
F
FREESTYLER
ya never know . still whenever u can pop that window switches cover and double check . its the most definative way to find out .
M
mrkersh
How do I pop the cover off? Just take a knife or screwdriver and pry it off? If so, i'll do it today. Thanks
you gently pry up on the wood cover, then you have 4 screw IIRC under the panel that needs to be taken out, then you can just look.
tragic1
