Rod mod/programmer question
ryan-in-oregon
...so you just set each corner to -50 and you get max lift all the way around?
Yes you would get max lift but it won't sit level. This adjustment is purely for calibration. On mine some of the sensors are off by quite a bit so for a standard level setting I have one at -17 and one at 25. This of course is an example because I did the calibration a month ago and don't remember the actual values.
Okay, so if you know the deltas between each corner you can simply ADD 25 to each of their original values, right?
Trynian
Actually it is subtract, the lower the value the higher the lift.
In Ryans case if his lowest calibrated corner is -17, the most he can do is subtract 33 to get -50 on that corner and then also subtract 33 from the other 3 corners to get the max lift he can. That should be about about 1.5 inches for 33 increments.
PE_in_UAE
