RRC Misfire
R
RRCSlovenia
Any ideas would be most welcome to my misfiring problem.... Here is the breakdown
92 RRC V8 - New Plugs, New Dist Cap, New Rotor, New HT Leads, New Fuel Pump, New Fuel Filter, New Pressure Regulator, New Coil, Timing checked!!!
Basically car will start fine runs a dream until she warms up. On the flat she purrs along until you put some load on the car eg up a hill or kick down or AC on. I have LPG if I switch over she runs fine no problems put her back on petrol and misfire will start if you put her under load??? It is only under load!! Down hill no problem!!
Tumbler
