Seafoam Question
62Sunbeam
OK. I've got my three pints of seafoam and I've heard people say put one in the gas tank (I'm OK with that), Suck one into the intake via a vacuum line (I'm ok with this to but I'd like to know if there is a better one to use than the hose going to the power brake booster) The pint I'm not sure of is in the crank case with the oil. I'm worried that a pint of seafoam will thin the oil too much and thereby affect the oil's lubracity( ability to lubricate properly - made that one up)
How long should I leave said pint in the crankcase before changing the oil?
Any and all help appreciated.
Eric
'95 Disco 167K miles (runs like crap)
R
roverX
Good question. I am also interested in the answer. Might I ad another question? What is seafoam and where do you get it? I have seen it mentioned several times on several boards.
62Sunbeam
You get seafoam at the beach.
Actually I found it at autozone.
Adding to the oil: I normally add about 500 miles before the oil change. It will not thin out the oil to the point it will not work. As per the can you should use 1 ounce per quart of oil, the can is 16 ounces the rover will hold 7 quarts.... so you are basically doubleing the amount needed. It will cause just about all of the oil gummed up oil in the engine to come loose, so I would not drive more than 500 miles on it after you put a can in it...
As to where to buy, NAPA, Autozone, Advance, or you can order online at:
http://www.midwayautosupply.com/detailedproductdescription.asp?10021
Vincentvip
