Sunroofs stopped working 95 D1
Zende
95 D1
After a long drive yesterday, I attempted to shut the roofs, but nothing!
I have never had probs with them before and I cant hear the motor working or any sound when pressing the front or rear switch..
Could this be a sunroof ECU fix, or a new motor(s)?
Checked all fuses and they are good.
Where would the motor and ECU be located?????
Any feedback always apprciated...
Thanks,
Zende
Please help
I found the ECU and motors for the sunroofs. I was able to close the rear sunroof manually w/ a hex wrench, but not the front ( it would not turn )
Is this because the motor may be seized or the glass is off track?
Im trying to find out if I should purchase a sunroof motor or ECU?
There is no clicking noise to the ecu when pressing the buttons.
Please help, before it rains
Thanks
sorry missed this post, sounds like a bad fuse or relay.... check voltage to the ECU also to and from the switch.
Zende
Fuses are ok.. Are you speaking of a relay within the ECU?
I ended up assuming it was an ECU problem and bought one from roverlandparts for $60. We'll see when it gets here tomorrow...
Thanks Joey.. Your help is always appreciated
Zende
Joey,
A new ECU solved the problem..
Thanks again..
gvillalongo
