Windshield washer pumps
DirtyHal
Spokane, WA
My windshield washer on the front quit working a week or so ago, I saw there were two on the parts diagram so I ordered two since I was in there anyways.
Turns out each pump has a different electrical connector. I have two of the smaller style that I got from rock auto. Can I get an adapter to make it work or do I need to buy the other style? If so how do I identify the larger connector style?
2nd question it appears my TPMS antennae got dislodged during this repair and I’m not sure what it is supposed to attach to?View media item 442View media item 443
DirtyHal
Spokane, WA
Just for closure in case someone searches this topic in the future I ended up getting the correct pump at the dealer. The larger oval plug is for the headlight washer. The other pump is for the windshield.
It is easiest to replace by taking off fender and inner fender to access washer tank. My issue actually ended up being a loose connection under the hood :rolleyes:
The TPMS antennae interestingly does not have a mounting spot. The dealer told it just floats so feel free to zip tie it to something if you want, that’s what I did.
Coffee
USA
Thanks for telling us how you resolved the two issues. I haven’t had to deal with either problem _yet_, but I’m sure my time is coming.
Cheers
Michael Gain
Clarksville, TN
The tpms antenna mounts to the fender splash shield within each wheel well. There are two plastic rivets with Phillips heads that attach them.
On the front, the are mounted on the inner portion closest to the front bumper.
00Jam
