Question for those with a rodmod lift
blackforestham
The 20's are just over 31". You might be fine as is. Since you are considering a 50 aspect ratio for a sidewall, I assume you won't be going offroad anytime soon. The DUB crowd likes the "filled" wheel well and yours might look good out of the box. Definitely consider relocating the wiring harness along the drivers front frame well area to avoid rubbing with the 285's.
brettmess24
Not much off road here in wisconsin, just some old logging trails for bird hunting in the fall. Tow a mastercraft in the summer and will keep the 19" with pirelli atr for the winter.
The coopers measure 31.29 and 11.63 wide and I see that the 285/60/18 are 31.48 and 11.43 wide.
Thanks for the insight I would get 18" but when it comes time to get an LR4 they will not fit. So thinking redbourne duke in 20".
PE_in_UAE
